rim and tire question
Of course, as long as it had the same bolt pattern.
Haven't you ever seen people bling blinging with bigger rims? Same applies to smaller ones -- but seriously, they look sort of weird. I think 17-18 is the best looking on these cars.
EDIT: And make sure to get tires for the 15" rims that would add up to equal the stock diameter, or else you've just changed your gear ratio.
Stock diameter of wheel + tire combined = keep it the same!
No, the stock tires will not fit on those 15x8 wheels because the tire is for a larger wheel.
Also, you have to watch out for brake clearance issues. I have heard of people having to grind the calipers to clear some 15 inch wheels.
Just be careful!
Just be careful!
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Hurin
Dec 13, 2014 07:38 PM
