Right turn signal dont work
Old Nov 23, 2003 | 01:55 PM
$hawn's Avatar
My right turn signal wasnt working, hazards, the rear one will flash but the front one didnt, a right turn signal , the rear would light up but would not flash, the front wont light up at all.
Put a new bulb in the front, now both will flash if hazards are on, and for a right turn signal they just stay lit. What else can it be, would a flasher only allow one side to work but not the other, i'd figure none would work. Any ideas.
Old Nov 23, 2003 | 02:21 PM
Zack's Avatar
did you get the right bulb? I just changed out a "bad" bulb. Turns out it was a 3057 instead of a 3157
Old Nov 23, 2003 | 02:27 PM
$hawn's Avatar
Mine are a 2057, the bad one was the same, funny thing is, it's only been in there for about a year.
Old Nov 26, 2003 | 09:15 PM
$hawn's Avatar
I need some help guys.
Old Nov 26, 2003 | 09:25 PM
pasmado15's Avatar
Have you checked the condition of the socket?
Old Nov 26, 2003 | 09:33 PM
VegasZ's Avatar
Check the bulb on the other side as well. These bulbs have a propensity to both go bad at once. Mine did.
Old Nov 26, 2003 | 10:31 PM
$hawn's Avatar
The other bulb(s) light up and flash, I cleaned the socket with rubbing alcohol, there some small spots that have rust, becuase the socket for some reason doesnt want to lock into place, but it's worked like that before, other than that, what would I look for in the socket. thanks
stangspank
Nov 13, 2015 01:02 PM
Injuneer
Dec 15, 2014 09:36 AM
NJLT1SS
Sep 11, 2002 02:29 AM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
