Rewiring O2 sensor
Old Nov 15, 2006 | 10:44 AM
BlackbirdWS6's Avatar
Rewiring O2 sensor
I've managed to semi-burn the wires running to my passenger side O2 sensor because they got too close to the long tubes. I noticed this issue when the car popped a code with low activity of that sensor. I've since wrapped the wires up in electrical tape and ran them in a way that won't let it happen again. I can tell that bank is still a little on the slower side so what's involved with doing this? Can I simply snip the wires and just run new wire for that section or do I need to run all new wire to the PCM?
-Brian
Old Nov 15, 2006 | 12:18 PM
reamo04's Avatar
u should be able to cut out the burnt wires and replace them with new wires
Old Nov 15, 2006 | 12:29 PM
I understand that, but will I need to run entirely new wire or can just cutout the bad portion and use new wire. The reason I ask involves wire resistance and such which could effect the readings to the pcm. Am I incorrect in saying this?
-brian
Old Nov 15, 2006 | 12:48 PM
reamo04's Avatar
as long as u use the same size of wire,it will not matterif u run all new wire, or just cut out the bad part
Old Nov 15, 2006 | 01:22 PM
hulettsz28's Avatar
Cut out the burn parts, as long as your using the game gauge/type.
Old Nov 15, 2006 | 01:37 PM
perfect, thanks guys.
Old Nov 15, 2006 | 01:44 PM
ZFan88's Avatar
I might have the same problem. Thanks for posting this
MDZ28
Sep 7, 2015 09:16 PM
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
