Reverse Oil Pressure???
Old Jan 4, 2004 | 03:34 AM
InjectedSS's Avatar
OK What the heck would cause the oil pressure to go the opposite way while building RPM's? Like my oil pressure will be at 50psi at like 3k, then I floor it in 4th gear and it goes the opposite direction, like LOWER psi I have an autometer electric oil pressure guage, check the connections and that's fine... This did this on my last motor too. I just barely rebuilt my motor just like I do almost every winter (new bearings, rings etc) and I just got done breaking it in and finally got a chance to get on it this weekend and I noticed that it's doing this all over again.. I can't figure out why it would be doing this...
Im going to install my stock oil pressure sender tomorrow to see if maybe the sender is bad. Has anyone else had this issue?
Old Jan 4, 2004 | 06:22 AM
Geezer powered's Avatar
What year car do you have? I'm going to guess a 94-95 right? do a search on this either here or the advanced section. It's the pan.
Old Jan 4, 2004 | 08:25 AM
slopokrodrigez's Avatar
Re: Reverse Oil Pressure???
And to think I only vacuum it out every winter?
Why on earth would you overhaul the bottom end every year
Don't trust any gage until you check it out first.
What is the clearance of the oil pump pickup to the oil pan? What is clearance with the bearings installed?
Old Jan 4, 2004 | 08:55 AM
Do you change the oil pump every time, too?
Old Jan 4, 2004 | 10:34 AM
NOMAD's Avatar
Cool
3 Scenarios :
1: Pump is too close to the bottom of the pan causing it to fight for oil.
2: You didn't replace the pump and it's shot
3: You've got toasted bearings
Either way, looks like your pulling the engine again. Might want to let a reputable shop rebuild your engine. I built 2 that didn't last over a thousand miles before I plunked down $1600 for a rebuild.
-Shannon
Old Jan 4, 2004 | 03:00 PM
InjectedSS's Avatar
Originally posted by NOMAD
3 Scenarios :
-Shannon
BRAND NEW oil pump and pickup just like I do EVERYTIME.
Bearings are BRAND NEW just as they are everytime.
Don't know about the pickup though. Maybe my 15W-50 oil is too thick
Welll Im off to try the different sender today. I will let you guys know how it turns out. Hopefully it's just the sender.. If that doesn't work Im going to try thinner oil... If that doesn't work then I dunno WTF
Because when you pull low tens and are shooting for 9's you tend to wanna make sure that everything is in perfect order Besides I wanted to change ring gaps and change a few other lil things You guys act like it's a big deal pulling the engine out or something. With a 2hr 42min record time to remove the engine, I can't see it bothering me anytime soon
Old Jan 4, 2004 | 03:18 PM
FastZinTennessee's Avatar
My motor does that too...... Lots of people have had this problem, when I switched to heavier 0w40 oil it really lessened the problem.
Old Jan 4, 2004 | 03:29 PM
I stand corrected, I never knew you had a bruiser. By all means, what you are doing would give a person piece of mind.
You obviously pull the engine from the top then, yes?
Have you chamfered the bearing cap hole where the oil enters from the pump? Helps prevent cavitation.
If your replacing the pump everytime, why wouldn't you check the clearance?
Are you running oil restrictors? Maybe the oil is staying up at the top too long?
How about a high volume pump with a shallow oil pan? Could that be the problem?
I won't bother you, just curious. Asking questions sometimes is the only way to learn.
Old Jan 4, 2004 | 04:06 PM
NOMAD's Avatar
Try lighter oil, around a 10w40. The 15W50 would be best for a loose clearance race engine that doesn't see many miles. Clearances are a important factor in this.
-Shannon
Old Jan 4, 2004 | 06:21 PM
Red_94Formula's Avatar
yea try a 10w or or 5w. with all new seal and all might as well use the 5w
Old Jan 4, 2004 | 07:54 PM
InjectedSS's Avatar
Well I tried a STOCK oil pressure sender and it's doing the same thing What's weird is if Im sitting idle, and I rev the motor up to redline the oil pressure is fine, doesn't drop at all... Even if I HOLD it up to like 5k rpms it stays up just fine. BUT like I said, when I get on it, it starts to go the opposite direction I dunno WTF the deal is.. I guess I will try thinner oil and see how that helps...
Hey BTW Im using the LONGER M1-302 filter does anyone know if that could be causing issues as well?
Old Jan 4, 2004 | 08:02 PM
96ltz's Avatar
Did you weld the oil pump pickup on?
Old Jan 4, 2004 | 08:45 PM
InjectedSS's Avatar
WERD... That thing isn't coming off for the end of the world
Anyone else?
Old Jan 4, 2004 | 09:17 PM
mebanditws6's Avatar
First thing you should do is switch to a K@N filter as the M1's are pretty restrictive, especially compared to the K@N. Also, did you replace the pressure relief spring? Get a higher pressure spring and see if the pressure still drops at prolonged high rpms. If you're seeing 50psi, you still have the stock spring in there, and it may just be getting worn, never know. Since you replace bearings and oil pump each year, I'm gonna assume the motor and the pan and pickup are all clean with no sludge blocking any oil passages. But if you still have the stock/original pickup, at least take that out and put it back in again, paying very close attention to how low it goes down into the pan. Finally, unless you set the clearance loose for 50wt oil, get that stuff out and switch to M1 0w40 or better 40wt synthetic (Redline, maybe Royal Purple).
Jason
Old Jan 4, 2004 | 09:44 PM
InjectedSS's Avatar
Jason
Pressure spring?? In the oil pump?? Please explain.
It's just a stock replacement M1-55 Melling oil pump.. The pickup and EVERYTHING is BRAND NEW EVERYTIME.. I don't take ANY short cuts...
So you think the M1's are too restrictive?? Im using the friggin $10 M1 oil filter. Is that the one your thinking of?
