Rev Limited?!?
Old Aug 21, 2005 | 10:30 AM
Heatmaker's Avatar
Advanced Member
Rev Limited?!?
I just recently had a tune done to push my car to 6200 RPMs.
I swapped out a 6K pill into my MSD 6Al for a 6.2K pill.
When I took my car out for a cruise a hit the Limiter at 6K. When I tried it
again I was able to get to 6.3K but it bounced tremendously.
In my driveway I rev the car up and it limits off at 6K Rpms.
I'm using a digital tach for my RPMs it's goes by incremenrts of 100RPM is very close to the same readings I got with the Tech 2 attatched to the car.
My tuner says the car was programmed for 6.2K
Does anyone know a reason why the car wouldn't go over 6K? which is it's old rev limit? Everything on the Ignition setup is new.
Old Aug 21, 2005 | 01:47 PM
93zted's Avatar
Re: Rev Limited?!?
Valve springs -over revving can cause irrepairable damage to them.
Re: Rev Limited?!?
Check the resistor in the pill... maybe its incorrect, or the contacts are dirty.
Old Aug 21, 2005 | 06:18 PM
Heatmaker's Avatar
Advanced Member
Re: Rev Limited?!?
Thier upgraded.
Old Aug 21, 2005 | 09:20 PM
1racerdude's Avatar
Re: Rev Limited?!?
Originally Posted by Heatmaker
Thier upgraded.
Free reving an engine sitting still to 6000RPM's will soon have a rod out the side of the block. What are the seat pressure and nose pressure of the upgrade?
Try another pill and see if it works.Sometimes they don't go to 6,200 and just shut down,they may lead into the shutdown a couple of hundred rpm's early.
Old Aug 21, 2005 | 09:26 PM
smoknta's Avatar
Re: Rev Limited?!?
You have a rev limiter set in the tune and in your MSD 6AL? I dont think you should be running both should you? Just one or the other. The tune will cut fuel and the 6AL spark? You may have them fighting against each other.
Old Aug 21, 2005 | 09:31 PM
Heatmaker's Avatar
Advanced Member
Re: Rev Limited?!?
Thier set to the same limits. The 6AL uses a soft touch rev. The 6AL is cotrolling the show..as far as I know. today I took it out... and I can shift at 6K... but it doesn't go past there... either good timing ... or i dunno what to think any more.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
