high end sputter and not shifting
Old Aug 20, 2005 | 09:15 PM
z28_theantirice's Avatar
I am having a high end sputter again I thought I solved it, but during a race today it didnt wanna shift until I let out of the gas, and you could hear the exhaust start to break up pretty bad. This problem dosent happen all the time, usually I can cherp second gear really good and get a little in 3rd. Im starting to think it only happens what its hot outside I could be wrong I dk?
So far I have replaced the coil with an MSD Blaster and also replaced the fuel filter. Im not sure what else I should check...Keep in mind i have an A4 with only 54k on the car
Old Aug 20, 2005 | 10:22 PM
Cmr0z28's Avatar
Re: high end sputter and not shifting
Sounds like you're hitting the rev limiter....mine did that. Sometimes it would get sideways between shifts, other times it would hit the rev limiter and pop, then shift.
If this is the case, your tranny is slipping and needs a rebuild.
Old Aug 21, 2005 | 08:57 AM
even on a tranny with 54k and not very much abuse??
Old Aug 21, 2005 | 09:51 PM
1racerdude's Avatar
What mods have been done?
Old Aug 21, 2005 | 09:52 PM
Cmr0z28's Avatar
Yep...sometimes it can be hit or miss. Since the factory tach is inaccurate, and the factory rev limiter doesn't "jolt" the car, but rather keeps the RPM's where they are, I used a scan tool to diagnose the problem, and confirmed that it was bouncing off the rev limiter.
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ezcheeze15
Aug 26, 2002 01:28 PM
squirrels
Jul 13, 2002 01:58 AM
pnbarbee
Jul 9, 2002 06:35 AM
