Rev Limit/shift point suggestions for my setup
Old Apr 24, 2003 | 12:19 AM
PoorMan's Avatar
Doing the mods in sig. I am going to get a pcmforless tune and need some suggestions on what my rev limit should be along with what rpm to shift at.
Thanks for the help.
Jeff D.
Old Apr 30, 2003 | 02:05 PM
PoorMan's Avatar
Trying again
Old Apr 30, 2003 | 02:40 PM
96ZRDR's Avatar
Well I have my Redline Limiter set a 6,800 rpm, but that because I have the MSD Limiter at 6,600 rpm. I rather have the MSD act as my rev limiter, then the coputer shutting me down.
PCM cuts fuel completely
MSD cuts of spark between intervals
I shift at 6400rpm. w xe230/236, Ported Heads, all bolt-ons.
I recommend you shift at least 6400rpm, that way you wont fall off your rpm range too much at each upshift.
I recomment you set your limit at 6,600 rpm depending on the age/quality of valvetrain-Bearings of the shortblock.
Old Apr 30, 2003 | 03:28 PM
mebanditws6's Avatar
6300 for shifting, 6600 for rev limiter
Jason
Old May 1, 2003 | 09:11 AM
PoorMan's Avatar
Thxs for the help guys.
Jeff D.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Feb 17, 2015 08:12 PM
