Reusing arp head bolts.
Old Nov 27, 2005 | 06:22 PM
Jameslt1TA's Avatar
Is this a good idea or not? Im getting some for free from a friend that im buying a heads/cam kit off of. Should i just spend the extra dough for added insurance or would it be a waste.
Old Nov 27, 2005 | 06:48 PM
Quickshotkimber's Avatar
Re: Reusing arp head bolts.
I've reused mine at least 5 times. In fact I'm bolting down a new set of heads as we type. Make that 6 times. Never had a problem. I would just clean them up with a wire wheel and look for defects. Also, ask your friend what he TQed the bolts to. As long as he didn't go overboard, I would use them.
Old Nov 27, 2005 | 07:10 PM
simple's Avatar
James,
i only used the head bolts once
torqued them too a max of 70-75lbft (cant remember exactly off hand)
went in 3 steps all around using factory sequence i think it was 30-50-70
like quikshot said, just hit'em with a wire wheel too clean up and be good too go
Old Nov 27, 2005 | 07:14 PM
If that's the case, I'll take em if you are still worried
Old Nov 28, 2005 | 09:19 AM
hawk232's Avatar
talented man there to be typing AND torquing heads at the SAME TIME
i have always heard they were designed to be reuseable, i think i read that from an arp ad
Old Nov 28, 2005 | 10:47 AM
Jameslt1TA's Avatar
Thanks guys. The only reason that i had any doubts is cause i have a friend that has built nascar motors and he said he wouldn't reuse em, but then again the dont reuse anything.
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
