which retainers and locks?
Old Apr 30, 2004 | 04:58 AM
Tofus 93Z28's Avatar
which retainers and locks?part number?
for the comp cams spring number 918-16... i have stock valves...
thanks in advance..
Old Apr 30, 2004 | 07:34 AM
MEAN LT1's Avatar
Re: which retainers and locks?
thanks in advance..
You can use Titanium retainer which which are very light or you can use the cast ones that comp sells. I dont think you'll go wrong either way, all the titaniums do is save a little weight off your valvetrain.
Old Apr 30, 2004 | 12:15 PM
part number
im sorry...more specifically..what comp cams part numbers..for steel
Old Apr 30, 2004 | 03:16 PM
Z-RATED94's Avatar
Iv'e got a set of 918's sitting in the closet. The retainers are part# 787-16, and the locks are 648-16. Hope that helps. And if you don't mind me asking, what cam are you using these springs with?
Old May 1, 2004 | 02:58 AM
fyi
small... the 304 actually came out of it...this is a rebuild... i had a set of crappy springs come apart and eat my guide seals up..so i and rebuilding the heads and doing a stockish rebuild on the lower end........ my initial plans this summer was to build a 383......but i decided....i want a house instead..so im going back together with the engine on a budget...
i just want it running...so i dont have to tow it into my new garage.....lol
Old May 1, 2004 | 03:10 AM
part number
these are all i can find..
http://www.jegs.com/cgi-bin/ncommerc...78&prmenbr=361
did a search on the 787 and no luck
on the retainers...
http://www.jegs.com/cgi-bin/ncommerc...75&prmenbr=361
maybe they change the part numbers...
Old May 1, 2004 | 07:35 AM
Don 97 SS's Avatar
Comp has a great website with mucho tech info. Check there directly to be certain
Comps' Website link
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
z28cam1993
Sep 9, 2015 04:08 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
