results of compression test
after storing the car for the winter I noticed the oil was a bit milky.I was thinking it was due to condensation over the winter.I changed the plugs today and thought I would do a compression test just to make sure while the plugs were out.
results are
#1=160 psi
#2=160psi
#3=160psi
#4=160psi
#5=160psi
#6=160psi
#7=160psi
#8=150psi
all were done with 6 compression cycles
should I be woried about #8 maybe head gasket leaking maybe?or nothing?
I would like some opinions
motor has 7 passes on it and 13 dyno pulls(no street miles)
thanks guys
results are
#1=160 psi
#2=160psi
#3=160psi
#4=160psi
#5=160psi
#6=160psi
#7=160psi
#8=150psi
thanks guys
I would not worry about it.
a leak down test will tell you alot more than cranking compression will.
But I think your fine, and you probly have a milkshake b/c of condensation. I see it on stuff if it sits a while
