resistor and diode question...
Old May 9, 2003 | 03:16 PM
slverbullet's Avatar
okay, this pertains the fan switch mod. ive had it done for a while now and gonna go ahead and put in the resistors and diodes so my ses will go out. as far as the resistor goes, i know they got to be 47 ohm's. according to the tech page it shows them parallel. so do i put them in parallel or one following the other? and as far as the diode goes, the tech page doesnt exactly say what size diode to use. any help? thanks.
dave
Old May 9, 2003 | 03:18 PM
tom3's Avatar
when in doubt, use a 1n4148, this is the most common all purpose switching diode around. they cost nothing (like 50c for 10 or so)
Old May 9, 2003 | 04:09 PM
Re: resistor and diode question...
dave
If you are referring to my page, it says 3 amp diode. I am not the author of that diagram and don't pretend to be an electrical genius.
Diodes only needed if your LEDs don't work right (like the page says). If you don't have LEDs, you don't need the diodes.
The resistors are for the SES. On one side there is one resistor in series and on the other two are in parallel (again, just like the diagram).
Old May 9, 2003 | 04:26 PM
eyeoutthere's Avatar
Just about any generic diode will do.
3 amps is a lot, and not really necessary. All you are switching is the relays, which only draw a fraction of an amp.
Old May 9, 2003 | 04:44 PM
i do run led's, so ill go ahead and put the diodes in. thanks guys.
Aug 18, 2015 07:08 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Tweaked Zed
Mar 22, 2003 03:26 PM
GREGG 97Z
Feb 7, 2003 01:11 PM
CJ Black LS1 Z28 M6
Middle Atlantic
Jun 15, 2002 10:12 PM
