Reseal LT1 Help
Old Nov 12, 2004 | 09:41 AM
jnco1xprez's Avatar
Reseal LT1 Help
Need to know how to do this. I want to change the intake gasket, timing chain cover gasket, oil pan gasket (most important)
where can i find instructions on how to do this procedure? I mainly need instructions on the oil pan gasket but all instructions are a help.
Also, planning to get high volume oil pump - which one to get and where to get it from???
thanx guys
Old Nov 12, 2004 | 10:33 AM
y5e06's Avatar
Re: Reseal LT1 Help
Use the search button.
Its been posted hundres of times, literally.
Just get a Melling oil pump. I just bought a melling 55HV (high volume) pump for $25 at my local OReillys. Get a new drive shaft w/ steel sleeve (not nylon) while your at it, $5.
Old Nov 12, 2004 | 11:40 AM
crash4cyl's Avatar
Re: Reseal LT1 Help
A chiltons maual, haynes manual will do wonders. AS he said a melling pump and drive shaft, then have the pickup tacked so it doesn't move (not neccissary, but I recommend it.). And you're best bet while doing the oil pan gasket will probably be to drop the k-member. And doing the front cover is easier with the motor out, but it can be done in the car. The intake is probably the easiest one you're trying to tackle.
Chris
Old Nov 12, 2004 | 12:50 PM
jnco1xprez's Avatar
Re: Reseal LT1 Help
Chris
Tacked? like stapled - kind of?
Will installing high volume pump cost me HP?
Old Nov 12, 2004 | 01:21 PM
y5e06's Avatar
Re: Reseal LT1 Help
tacked, as in tack welded.
the power loss with a HV pump is totally insignificant.
Old Nov 12, 2004 | 01:29 PM
crash4cyl's Avatar
Re: Reseal LT1 Help
the power loss from it is negligable. Would you rather have a good volume of oil through your motor or worry about losing 1/4 of a hp?? I'd choose oil, besides as you get more miles on your motor it'll take more volume to get the same pressure as a stock volume pump in a new motor.
Chris
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
