Reseal LT1 Help
Old Oct 5, 2004 | 12:11 PM
jnco1xprez's Avatar
Reseal LT1 Help
Thinking of something to do and this came to mind. Why not reseal, change all the gaskets on my LT1 and add a high volume oil pump to raise the pressure a little.
Questions:
1. how hard is it to change the oil pan gasket/seal and what is the procedure for this, while doing this while the car is on 21" jack stands.
2. has anyone done this and any benefits.. as in engene pressure gains. my main concern is to stop the madness with the oil leaks and to raise oil pressure.
3. Where should I get lower gasket set, everything below the block and also the manifold gaskets. i guess i need them all except the head gaskets.
Also, the high volume oil pump.
Thanx in advance
Old Oct 6, 2004 | 01:37 PM
jnco1xprez's Avatar
Re: Reseal LT1 Help
noone can help?
How about just the oil pan..... can i just remove it without having to touch the k-member?
anyone know this? i just need to know how to change the oil pan gasket
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
