Reseal LT1 Help
Thinking of something to do and this came to mind. Why not reseal, change all the gaskets on my LT1 and add a high volume oil pump to raise the pressure a little.
Questions: 1. how hard is it to change the oil pan gasket/seal and what is the procedure for this, while doing this while the car is on 21" jack stands. 2. has anyone done this and any benefits.. as in engene pressure gains. my main concern is to stop the madness with the oil leaks and to raise oil pressure. 3. Where should I get lower gasket set, everything below the block and also the manifold gaskets. i guess i need them all except the head gaskets. Also, the high volume oil pump. Thanx in advance |
Re: Reseal LT1 Help
noone can help?
How about just the oil pan..... can i just remove it without having to touch the k-member? anyone know this? i just need to know how to change the oil pan gasket |
