Reprogramming Remotes......
When I bought my car I only got one with it.
My sister had a 99 Alero which has the same GM remotes.
When she sold her car she unknowingly kept one and has now passed it on to me - in the hopes that I can use it on my Camaro somehow.
Is there any way to get it to work?
Thanx for your help.
on the camaro to reprogram the remote simply remove #14 fuse (radio fuse) from the left side dash fuse block then turn on the car the doors should cycle lock unlock and the trunk should pop... then simply hold the lock and unlock on each of the remotes (do all of the nes you have you can do upto 4 for these cars) until the doors cycle again... when your done just simply turn off the key and put the fuse back in and your done!!! its that easy on the f-bodies (btw im a gm technician lol)
Aug 7, 2015 08:52 AM
steelheart
Dec 8, 2002 02:10 AM
