Reprogramming Remotes......
Old Aug 7, 2003 | 07:06 PM
Pandamonkey's Avatar
When I bought my car I only got one with it.
My sister had a 99 Alero which has the same GM remotes.
When she sold her car she unknowingly kept one and has now passed it on to me - in the hopes that I can use it on my Camaro somehow.
Is there any way to get it to work?
Thanx for your help.
Old Aug 7, 2003 | 07:46 PM
Red96Lt1's Avatar
You can alway go to the chevy dealership and have them do it. I've seen a website that shows you how to do it, I'll try to look for it.
Old Aug 7, 2003 | 07:50 PM
jchevy's Avatar
Look for a post by shoebox, he has a link in his sig to his website and it is on there, very easy to do.
Old Aug 7, 2003 | 08:11 PM
jbeamj's Avatar
on the camaro to reprogram the remote simply remove #14 fuse (radio fuse) from the left side dash fuse block then turn on the car the doors should cycle lock unlock and the trunk should pop... then simply hold the lock and unlock on each of the remotes (do all of the nes you have you can do upto 4 for these cars) until the doors cycle again... when your done just simply turn off the key and put the fuse back in and your done!!! its that easy on the f-bodies (btw im a gm technician lol)
Old Aug 7, 2003 | 08:20 PM
jchevy's Avatar
You need to cycle the ignition from off to on 4 or 5 times after you pull the radio fuse.
Aug 7, 2015 08:52 AM
HCz28
Feb 15, 2015 03:01 PM
Rod Bender
Jan 3, 2015 03:15 PM
555PREZ
Pacific
15
Feb 1, 2003 01:08 AM
steelheart
Dec 8, 2002 02:10 AM
