Reprograming??
Old Dec 11, 2003 | 08:27 PM
BigTed187's Avatar
Reprograming??
hey i was wondering if i needed to reprogram my pcm/ecm because i put 26 lbs injectors in and a new egr valve?? but i stil lhave a stumble....i got a 1995 z28 ....i was wondering if not reprograming the computer have something to do with the problem still??
Old Dec 11, 2003 | 08:30 PM
Z28ROC's Avatar
Try resetting your pcm, by pulling the pcm/batt fuse.
Old Dec 11, 2003 | 08:33 PM
BigTed187's Avatar
is that on the dirver side close to the steering column?? thanx alot...
Old Dec 11, 2003 | 08:42 PM
wicked_95z's Avatar
Or you couold just remove the neg battery cable for about 10 mins I believe it is
Old Dec 11, 2003 | 09:50 PM
97WS6SCharged's Avatar
No, you shouldn't need to reprogram the computer for 26 lb/hr injectors. If you're getting a stumble, I would check the plugs and wires. If nothing is wrong there, it may be the dreaded Opti.
Old Dec 11, 2003 | 11:31 PM
Z28ROC's Avatar
yes just pull it for a second and put it back in. That will reset the pcm.
Old Dec 11, 2003 | 11:36 PM
madwolf's Avatar
Are those 26#s ACCEL or LS1 injectors? If they're ACCELs, you will run slightly rich without programming, but not very bad. If they're LS1 injectors, you will run lean. They were rated as 26.4# at 58 PSI and we run 43.5 At 43.5, they will flow 22.5 or so.
Old Dec 12, 2003 | 12:29 AM
Hmm... I didn't know the LS1 ran on 58 PSI. I thought they only differed by using a non-return style regulator. Good to know.
Aug 7, 2015 08:52 AM
HCz28
Feb 15, 2015 03:01 PM
Rod Bender
Jan 3, 2015 03:15 PM
555PREZ
Pacific
15
Feb 1, 2003 01:08 AM
steelheart
Dec 8, 2002 02:10 AM
