Reprograming??
Reprograming??
hey i was wondering if i needed to reprogram my pcm/ecm because i put 26 lbs injectors in and a new egr valve?? but i stil lhave a stumble....i got a 1995 z28 ....i was wondering if not reprograming the computer have something to do with the problem still??
Are those 26#s ACCEL or LS1 injectors? If they're ACCELs, you will run slightly rich without programming, but not very bad. If they're LS1 injectors, you will run lean. They were rated as 26.4# at 58 PSI and we run 43.5 At 43.5, they will flow 22.5 or so.
Aug 7, 2015 08:52 AM
steelheart
Dec 8, 2002 02:10 AM
