Replacing Low Oil Sensor..on a 96
Old Mar 25, 2006 | 10:11 PM
Jazsun's Avatar
I tried removing it but its just too long and it hits the y pipe when I try to pull it out. Any alternative to dropping the y pipe and breaking all the bolts?
Old Mar 25, 2006 | 11:23 PM
FastZinTennessee's Avatar
Re: Replacing Low Oil Sensor..on a 96
Probably not. Dropping the Y-pipe seems to be the most logical choice to me, even though I haven't replaced one while in the car. If you try to drop the oil pan, the sensor will hit the stock windage tray and keep the pan from dropping, so that won't work.
If it were me, I'd soak all the bolts/nuts that need to come off with some WD-40 or PB Blaster a few times before removing them.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
