This is replacement or add on?
Old Aug 11, 2010 | 06:06 PM
Chaos1187's Avatar
Does this replace the air box or does it connect to it somewhere as a add on to what is already there??
Old Aug 11, 2010 | 06:13 PM
bigjoebowski22's Avatar
It appears to be replacement, however, I've been known to be wrong before.
Old Aug 11, 2010 | 06:17 PM
LSWHO's Avatar
Is that supposed to aim backwards toward the drivers side tire well? that's what it looks like to me...
Old Aug 11, 2010 | 06:44 PM
Chaos1187's Avatar
Im really not sure to be honest, it looks pretty tiny to be sucking in air into the engine. Thats why I didnt know if it was a add on to whats there or a replacement.
Old Aug 11, 2010 | 07:13 PM
TD95Z's Avatar
It's the SLP cold-air kit for an LT1. It replaces the airbox entirely. The plate on the bottom goes where the stock airbox is, the right side of the pipe (as shown in the pic) goes down to the plate, the filters go on from the bottom, the left part (again, as shown in the pic) goes to the throttle body. You still retain the rubber elbow leading to the throttle body.
BTW, it's a perfectly good piece. It functions the same as any cold air; it just has 2 filters instead of one. Kinda pricey, but a nice piece nonetheless.
Old Aug 11, 2010 | 07:35 PM
Chaos1187's Avatar
Okay cool I appreciate that I didnt know what the deal with it was and didnt wanna buy it and it not be what I wanted. I got another one since you seem familiar with the intake. On the rubber elbow portion underneath pointing towards the air dam (spelling) I have a oval shaped portion that has been taped up (previous owner) I looked inside the elbow and it looks like its opened through again pointing towards the air dam. What is that opening for?
Old Aug 12, 2010 | 06:38 AM
TD95Z's Avatar
The opening is for a silencer tube, used to quiet the intake down for noise regulations. You can plug the hole, or just buy a new elbow. Personally, I've always switched to a Trick Flow elbow when installing a cold air. Either way, you don't want a big hole in the elbow sucking in unmetered air, so if that is open, address it asap.
Old Aug 12, 2010 | 08:08 AM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
My car wouldn't run with that hole not plugged.
Old Aug 12, 2010 | 08:18 AM
TD95Z's Avatar
It shouldn't. That's a massive amount of air that isn't being seen by the MAF. I only mentioned it since the OP said he took off the tape that was covering it.
Old Aug 12, 2010 | 08:55 AM
Chaos1187's Avatar
Well I didnt pull the tape off but I did check it out, and I covered it back afterwards. I was looking at one of those elbows they look a lot nicer then the current rubber one. Do you know if by chance they sell any polished ones? Ive seen the silverish dull looking ones but not any nice finished ones.
Old Aug 12, 2010 | 09:00 AM
TD95Z's Avatar
I used to have the ceramic coated Trick Flow. Current one is black. I imagine someone makes a polished one, but I don't know for sure.
Old Aug 12, 2010 | 09:13 AM
Chaos1187's Avatar
I found the ceramic coated one I believe by trick flow, its coated and is a lot nicer looking then the other one I had found. Its for 99, sound about right?? On Summit Racing website.
Old Aug 12, 2010 | 11:03 AM
koolaid_kid's Avatar
That is the one you want. However, Summit lists it as out of stock, so you might want to check elsewhere. BTW, it is a nice piece and contains everything you want (clamps, hoses, elbow). Be aware that you will need to drill a hole in the bottom to fit the Opti vent hose.
HectorM52
Jun 23, 2016 08:42 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Dec 5, 2014 11:42 AM
guionM
13
Sep 5, 2002 09:58 PM
