Pop/backfire from pass side exhaust
Old Aug 11, 2010 | 12:57 PM
kgkern01's Avatar
So after 2 years, my car finally has a new engine and runs, but I have a very loud exhaust pop coming from the pass side. Doesn't seem to do it at idle, but as soon as i give it any gas, POP! With the cutout open it REALLY sounds like backfire, but not as bad with it closed, but still embarassing! Hesitates and seems to have low power. :eek2:
I degreed the cam upon install...twice, the timing set is dead on, as well as the opti is lined up correctly, and I adjusted the valves with 1/2 turn preload....all of this done on the engine stand before install to make sure was done 100% correct. What to check out for this, spark plug wires? Readjust the valves? Anything else?
It's my day off so I want to go out driving around in this car I haven't driven in 2 years!!! :drive:
Old Aug 11, 2010 | 01:40 PM
lt1-xjs's Avatar
Do you have it tuned for the cam?
Old Aug 11, 2010 | 03:23 PM
kgkern01's Avatar
Yeah I have a tune from Ion (madz28.com) for the cam, and since using E85, all I tweaked on it was the WOT tables so far. It's only coming from the passenger side, and sounds like unburned fuel igniting in the exhaust.
Old Aug 12, 2010 | 12:07 AM
kgkern01's Avatar
Found it to be cylinder #5 actually. I pulled the injector plugs one at a time until I no longer got a backfire, and #5 is the only injector that, when disconnected, causes the backfire to stop.
So I pulled the plug wire, visually looked fine, went ahead and readjusted the #5 exhaust valve, it was fine, could slightly move it side to side when on the base of cam, but, readjusted anyway. Next, I used a spark tester, clamping one end to the top of the spark plug and the probe in the end of the plug wire, and it made spark while the engine ran (injector unplugged). So I clean up the terminal of the plug boot, reinstall it on the plug, plug the injector back in and....POP!
So now that I have tested spark with a spark tester, readjusted the valves...now what???
Old Aug 12, 2010 | 02:49 AM
lt1-xjs's Avatar
Have you scanned it for codes and did you look at the plug itself ? Maybe that injector is bad, switch it with another. If that doesn't work and it's still #5, I'd do a compression check on that cylinder.
Old Aug 12, 2010 | 06:17 AM
kgkern01's Avatar
No codes, I'll pull the plug after work today, hopefully it is just fouled out. I'm going to pickup a new plug and set of wires today after work and see if that does it. If not I'll try swapping the injector to another cylinder.
Old Aug 12, 2010 | 01:07 PM
kgkern01's Avatar
We have a winner....and I'm a retard for not noticing it sooner! 5 and 7 were swapped at the opti. However, the #5 plug also was cracked, so that probably didn't help. Running smooth now!
Old Aug 12, 2010 | 05:14 PM
lt1-xjs's Avatar
wonderful !
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Chris Anderson
Jan 27, 2015 08:30 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
guionM
18
Jul 11, 2002 01:45 AM
