replaced water pump and now have a oil leak
Old Oct 18, 2010 | 11:32 AM
wildracer's Avatar
just like the title says... i replaced the water pump on my 97 z28 30thyr and now i have a oil leak thought it was the oil pan or timing cover but after looking more closely its doent seem to be coming from there.. any ideas on where this could be coming from???? thanks for all the help guys
Old Oct 18, 2010 | 11:44 AM
wildracer's Avatar
sorry guys forgot to tell you that it is a lt1 motor
Old Oct 18, 2010 | 04:55 PM
Procharged94Lt1's Avatar
Potentially could be the drive seal from when you changed the pump..start there.
Old Oct 19, 2010 | 05:08 AM
Not realy an "Advanced Tech" topic..... Moving to LT1 Based Engine Tech.
Old Oct 19, 2010 | 11:13 AM
my left foot's Avatar
I second on the drive seal. You can disturb it and the timing cover when changing out the WP.
Old Oct 19, 2010 | 12:17 PM
wildracer's Avatar
thanks guys ... ill let you know how things go after this weekend ill be putting in a new radaider so ill check the pump out at the same time... i did go on shoebox and found that there is a o-ring that i didnt know about there on the shaft that goes into the timing cover.. so ill change that and let you all know how it goes ... thanks for all your help
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
