replaced o2's now car won't start!!!
Old May 15, 2006 | 05:23 PM
jbh2317's Avatar
First of all, any help would be appreciated! I bought a 95Z some months back with around 135K. Two days later it started severely overheating. To try and make a long story short there was water in the some cylinders and a blown headgasket. Proceeded to tear down the top half and start refreshing. At this time I installed headers and true duals. I got the heads resurfaced and new seals new gaskets, new delco plugs, wires, water pump, and hoses, new cap and rotor, new coil, and a rebuilt distributor (money was tight). I also deleted the air and egr. After all that the car ran good for about a week and then came my new problem, the car started missing badly and running very rich. I just replaced the 2 oxygen sensors and at first car wouldn't crank. Tried a second time and it cranked revved up to about 2K then idled down to about 800 where it was very erratic. It started sounding like it was about to go dead so I shut it off. Now car won't crank at all???
Old May 15, 2006 | 07:05 PM
hotrod18_69's Avatar
Re: replaced o2's now car won't start!!!
Sound like your rebuilt Opit just died! Where did ya get it at? I would try and take it back and get a GM one..
Old May 16, 2006 | 12:28 AM
redimpss5's Avatar
The car on a stock motor will run like crap without the egr. Look at the coil and coil wire also.
Old May 16, 2006 | 12:42 AM
95patriotZ's Avatar
I removed my egr on a basically stock car and it still runs fine. No problems at all. When you say it won't crank do you mean it doesn't do anything, or the car cranks, but doesn't fire?
Old May 16, 2006 | 11:35 AM
jbh2317's Avatar
It will turn over, just not start. When it had the original o2's before the swap and it was missing and running rich, the car would run fine until it reached operating temp then would start missing. Also after it would start missing while driving sometimes it would just go away and run fine for a while then start back missing?? So I replaced the o2's and now she won't start!
Old May 16, 2006 | 12:38 PM
stereomandan's Avatar
Doesn't seem like an O2 problem. The car runs in open loop until it's warmed up anyway. Sounds like you crossed some wires, have loose wires, or a bad opti. Check all your fuses.
Dan
Old May 16, 2006 | 01:00 PM
1SlowFormula's Avatar
I agree with Dan, O2's should not cause a starting problem...
Old May 17, 2006 | 09:21 AM
JB94's Avatar
I had a similar problem with my 94 a couple of weeks ago.turned out to be the coil wire.Had the same symptoms/engine revving high/erratic idle/it also set a trouble code and turned the fans on.I replaced the coil and plug wires and it's been fine since.
Britbilly
Jan 7, 2015 08:49 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
