waterpump install
Old May 17, 2006 | 09:32 AM
guyette117's Avatar
waterpump install
how hard is it to change your waterpump by yourself...
Old May 17, 2006 | 09:37 AM
OBE1 95Z28's Avatar
Re: waterpump install
It's a straight forward job. Just be sure to drain the coolant from the block as well as the radiator otherwise you'll get your opti wet. Use teflon sealant on the waterpump bolts when you reinstall them. Also make sure you transfer the drive coupler from the old one to the new one.
Old May 17, 2006 | 11:08 AM
1SlowFormula's Avatar
or upgrade to an electric unit, more HP at close to the same cost of stock replacment...
http://www.projecttransam.com/projects9.asp
Nov 18, 2023 07:21 PM
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Wilson
Jul 21, 2002 05:08 PM
