replaced EGR still getting SES
Old Feb 2, 2005 | 02:44 PM
SteveLogan's Avatar
I replaced my EGR and did the intake manifold oil leak fix at the same time. I had to replace my EGR to get it inspected. When I took the car to get inspected the computer was still in 'not ready' mode so it failed. I assumed I just needed to drive it more to let the computer reset. I got an SES a few days later and took it to get a free scan at autozone. It's still getting an EGR code but not the same as before. Now, when I replaced the EGR and was putting everything back together I broke a vacuum line that was on the drivers side near the back of the intake. I couldn't find where the other end went to so I just taped it off. The car runs great, but I'm guessing this vacuum went to the EGR and that's why it's throwing a code. How many vacuum lines go to the EGR and could this be causing the code? Thanks for any replies.
Old Feb 2, 2005 | 02:55 PM
Max 93's Avatar
Re: replaced EGR still getting SES
it's probably the vac line that goes to the EGR selinoid
Old Feb 2, 2005 | 02:56 PM
Looks like you broke the vacuum line to the EGR.
Old Feb 2, 2005 | 03:00 PM
SteveLogan's Avatar
Ok, that diagram helped a lot thanks. So can I replace the line with just some rubber tubing or does it need to be hard plastic?
Old Feb 2, 2005 | 03:06 PM
If it is on a long section, you could splice out the damage with a piece of rubber vaccum line, but for the parts with the 90° bends, a rubber line is not going to work very well.
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
thenewkid
Nov 18, 2014 12:57 PM
CobraEatr
Jul 29, 2002 11:46 AM
