replace LT4 KM and Knock sensor?
Old Dec 20, 2004 | 11:43 PM
Eric85's Avatar
Well i know for a fact ill be replacing the KM in the ECU but my questions is do i really need to change the knock sensor also? I need the part number for the KM so i can order it tomorrow though.
One more thing. I know the KM is simple to put in but what about the knock sensor? I know its on the bottom of the block but how hard is it to switch out?
Old Dec 20, 2004 | 11:47 PM
94zLT1's Avatar
Re: replace LT4 KM and Knock sensor?
http://www.gmpartsdirect.com/results.cfm
here ya go and i dont think the knock sensor needs to be changed unless u know its malfunctioning
Old Dec 20, 2004 | 11:51 PM
Brent94Z's Avatar
Super Moderator
You can use the LT4 Knock module in either an OBDI or OBDII PCM but if you have an OBDI PCM, you'll want to stick with the OBDI 3.9k ohm knock sensor vs. the OBDII 100k ohm knock sensor. Just FYI since you didn't mention if you're running OBDI or OBDII
Old Dec 21, 2004 | 12:02 AM
Eric85's Avatar
No parts were found matching your search.
Please try our alternate catalog for locating the part you need
Thats what it says when i open it up. So if the Knock sensor isnt malfunctioning it wont pull timing or anything of that nature? Thanks Guys.
Old Dec 21, 2004 | 12:09 AM
94zLT1's Avatar
16214681
go to gmpartsdirect.com and put in this #
sensor is prolly fine
run logs to see if ur getting knock
Old Dec 21, 2004 | 12:11 AM
Brent94Z's Avatar
Super Moderator
If you aren't having problems with knock retard (false) then there really is no sense in replacing the knock module or the knock sensor. The knock sensor only really needs to be replaced if it is "broke" and then the knock module some guys switch to the LT4 version if they are seeing false knock retard. But, if you aren't seeing knock retard, really no reason to change that out either.
Eric85's Avatar
im pretty sure i am. Everytime i mash the gas the truck will bog for about 10 seconds then it will be fine.
Old Dec 21, 2004 | 12:14 AM
Brent94Z's Avatar
Super Moderator
You'll save money in the long run if you get a scanner for your car and monitor some of the parameters. You are going to spend a lot of $$$ just by throwing parts at it because it is bogging... that could be a number of things and is likely not the knock sensor/module
Old Dec 21, 2004 | 08:43 AM
I doubt very seriously that the LT4 KM is going to do anything for your bogging. You need some diagnostic data to troubleshoot your problem. Brent has some good advice.
Old Dec 21, 2004 | 10:48 AM
"White Knight"'s Avatar
definately worth it if you have headers.......it's a must buy. Does wonders if you are getting false knock on a loud high milage engine. Get it---it's like 30 bucks....i gain some e.t. back with it. It won't help with the bogging down though....that sounds like something else and more severe.
Old Dec 21, 2004 | 11:43 AM
Several very knowledgable people have told you what to do.... scan the PCM for knock retard. If you don't have any, you don't need the LT4 KM. Even if you find knock retard, you need to determine whether it is "real" or "false".
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
