removing stock exhaust manifolds
Old Aug 5, 2003 | 10:03 AM
Dave19yz28's Avatar
Just wonderin if anyone has anytips for me...I need to take off the passenger side on to block off the egr thingy...im havin way too much trouble tryin to get the block off plate on with the manifold still on the car...also, when taking the alternator off...anything i whould worry about, with the serp. belts or otherwise? Thanks for the help guys.
Old Aug 5, 2003 | 11:07 AM
Dave19yz28's Avatar
on a side note...what size are the header bolts...and do i need a contorsionist to get this thing off????
Old Aug 5, 2003 | 11:19 AM
PatriotTA's Avatar
Just take the alternator off, don't have to worry about anything except the wire harness on the bottom, its not very long, so don't stretch the wires when you remove the alt. Just unclip it. I'm not sure what the thread pitch of the exhaust bolts are, but I'm pretty sure the heads are 9/16, if you are asking what size socket to use. All of the are pretty easy except the last one (near the firewall). For that one, your guess is as good as mine. I used a 1/4" ratchet and a 9/16 wrench. The first one or two (near radiator) you can get from the top, the other 4 can be had from underneath. And when you're on that last bolt, remember - patience is a virtue
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
