Removing steel plug from aluminum LT1 heads
Any suggestions for removing the steel square hole pipe thread plug from a 95 LT1 aluminum head?
Have the engine up and running in a 37 Chevy and need to leave the OEM temp sender on the drivers side... would like to install an aftermarket temp sender in the plug hole on the passenger side head for the dash temp gauge. Torqued a little with a square head socket via a 3/8" drive ratchet...but just get that "feeling" that I need to back off before something breaks Do have coolant in the block...any suggestions? Thanks |
Re: Removing steel plug from aluminum LT1 heads
I believe the size of the square is 5/16", just so you don't round it out.
Originally Posted by shoebox
(Post 6979232)
10-4... I even have a Snap-On square socket for the plug. |
OK..got out today! Thanks...
