Removing Stage 8 Bolts???
Old Feb 17, 2003 | 01:12 PM
JulietZ28's Avatar
Question Removing Stage 8 Bolts???
Hey guys i have a header leak on the slip-fit primary on my longtubes and i cant seem to get the stage 8 bolts off to fix it. What do u guys use an allen wrench? I dont think a normal wrench can fit in there. Please help
Old Feb 17, 2003 | 04:11 PM
joeSS97's Avatar
Use the right size allen wrench.
Old Feb 17, 2003 | 04:16 PM
EviLBoX's Avatar
It depends which bolt and how much room you have to work with. On several of my bolts I can use a ratchet with an allen wrench head to loosen/tighten them, on the others I have to use an open wrench shaped like a "C" (crescent wrench?).
Old Feb 17, 2003 | 05:01 PM
JKDZ28's Avatar
kinda off topic , but did you guys use that anti-seize stuff on the sliptube?
Old Feb 17, 2003 | 05:13 PM
JulietZ28's Avatar
JKDZ28, After posting about this for a week or so most people seem to use RTV high-temp selant or a small exhaust clamp for the slip-fit primary so thats what im gonna try for my slip-fit leak.
Old Feb 17, 2003 | 08:36 PM
Bud M's Avatar
Yeah, a 1/4" drive ratchet with an allen wrench socket is good to have for Stage 8s and so is the proper size (7/16 if I remember right) ignition wrench. Or you may be able to grind enough material off an open end wrench to fit it in some tight spots.
Old Feb 17, 2003 | 08:42 PM
JKDZ28's Avatar
so no RTV stuff if i got the clamps???
i got the clamps!!!!
Victor Lamb
Aug 26, 2017 02:52 PM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
