Is removing and reinstalling (Torqing) the heads possible with the engine in the car?
Old May 17, 2005 | 11:51 AM
DemonZ28LT1's Avatar
I was wondering if removing and reinstalling (Torqing) the heads possible with the engine in the car? I was just trying to figure out how hard it would be. Why? Because I am rebuilding it and I have everything but my heads arent in yet so I wanted to install the engine headless until I got them and then strap on the heads. Is this possible? Is it a pain?
Old May 17, 2005 | 12:06 PM
sssalah's Avatar
Re: Is removing and reinstalling (Torqing) the heads possible with the engine in the car?
Yes it's possible, but is easier done on an engine stand obviously. Wach out for the steam vent tube, it could be tricky installing it with the motor in.
Old May 17, 2005 | 12:17 PM
I was just wondering if you'd recommend I wait till I get the heads (I have like 1 1/2 WKS to get done) and waste more time by having to install everything else after or should I Install the block then put the heads on with the brackets etc. installed.
Old May 17, 2005 | 12:52 PM
sssalah's Avatar
If installing the engine from the bottom then wait till you get the heads so you can fix the headers on at the same time. If from the top it's easier without the heads and the housing bolts will be easier to get to.
Old May 17, 2005 | 01:22 PM
Blownbird355's Avatar
Yeah like they said wait torque readings will be accurate.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
97SSdude
Dec 31, 2014 07:43 PM
mattszm6
Dec 14, 2014 07:09 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
