removing lower timing gear
Old Jan 31, 2009 | 04:32 PM
sn8ke eatr's Avatar
Angry removing lower timing gear
im sorry if this sounds like a stupid question.. im exhausted and freezing and my brains not on 100% right now
the lower gear, on the crank, has that little keyway thing to keep the timing gear from spinning on the crank. does that little keyway thing get pushed down as the gear is coming off? i was crankin on the damn puller and the timing gear wouldn't budge! i already snapped a pep boys timing gear remover so i had to grind down and modify one i had already. i have the leverage/puller etc but im afraid of damaging the motor.
is there anything else im missing? i know its gonna be obvious.. should i just go for broke and just crank on it harder? i dont wanna F up the crank,..
can someone help a brother out?
Old Jan 31, 2009 | 06:15 PM
The key is normally not in the way, as the gear has to slide over it to go on.
http://shbox.com/ci/crank_sprocket.jpg
Old Jan 31, 2009 | 06:41 PM
sn8ke eatr's Avatar
the part of the key that is raised over the surface of the crank, does it press down to become flush with the crank or does the timing gear have the indentation to allow it to slide over the raised key?
Old Jan 31, 2009 | 08:36 PM
RUDEDOG's Avatar
It will slide over the key.
Old Feb 1, 2009 | 03:50 PM
sn8ke eatr's Avatar
ok so just crank on the thing huh? am i in danger of ruining anything? id imagine that gear is pretty strong right?
Old Feb 1, 2009 | 05:08 PM
RamAir95TA's Avatar
Nope it'll be fine.
Old Feb 1, 2009 | 06:30 PM
sn8ke eatr's Avatar
alright then looks like its time to pull out the breaker bar..
ramair95 im holding you personally responsible for any damage
thanks guys
Old Feb 1, 2009 | 06:48 PM
RamAir95TA's Avatar
Are you using a 2 or 3 toe puller?
Old Feb 1, 2009 | 07:28 PM
sn8ke eatr's Avatar
three
Noenav
Mar 1, 2019 07:38 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
