removing keyed hub off crank???
Old Feb 1, 2007 | 08:40 PM
AlmostfastLT1's Avatar
I am trying to remove the hub that holds the balancer. I am trying to remove it off the snout of the crank.
Jaw puller wont work, what did you guys use...
Thhanks
Mark
Old Feb 1, 2007 | 08:46 PM
OBE1 95Z28's Avatar
A common mistake is that your pushing against the hub with the center bolt of your puller. You need to may sure you're pushing against the crank and the not the hub.
Old Feb 1, 2007 | 09:32 PM
Sweetred95ta's Avatar
Remove the center bolt (5/8", I believe) and use a crank pulley puller. Get some long 9/16" bolts (old water pump bolts work well) and use washers. It'll pop off.
Old Feb 1, 2007 | 11:00 PM
And, just for clarification... if your hub is stock, it isn't keyed to the crank.
Old Feb 2, 2007 | 12:29 PM
you know what I mean, everyone seems to call it that...
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
