Opti Preventative maintance?
Old Feb 2, 2007 | 11:28 AM
The Captain's Avatar
Well since the opti in our cars is notoriously knows to screw up either by itself or with the help of the water pump, is there anything I can do to prevent it from crapping out?
Old Feb 2, 2007 | 11:31 AM
jsetzer's Avatar
- Check your vacuum hoses. Make sure there are no crack, leaks, blockage.
- Some people like to tighten / locktite etc the scews holding the rotor in place
- you can rtv the seal on the case to help make it water tight, better be clean though. Could get messy inside.
Of course I only speak for the vented optis, dont know the old ones.
Old Feb 2, 2007 | 11:32 AM
2000GTP's Avatar
Not much you can do other then preventing it from getting wet.
Old Feb 2, 2007 | 11:37 AM
Well if I understand correctly the 93s came with a sealed opti, so would RTVing it really be worth the trouble?
Old Feb 2, 2007 | 12:06 PM
TobyZ28's Avatar
I would think checking that the vaccume lines are working correctly and not blocked would be the best preventative maintenance you could do on a higher milage opti
Old Feb 2, 2007 | 01:00 PM
buzz12586's Avatar
Leave it in the box.
Old Feb 2, 2007 | 01:11 PM
2000GTP's Avatar
That would be good if he had a vented opti, but seeing that he has a 93, it is non-vented.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
