Removing Intake. Got a RTV question and looking for helpful tips
Old Jun 5, 2011 | 06:27 AM
  #16
RobsWS6's Avatar
Re: Removing Intake. Got a RTV question and looking for helpful tips
I've used Ultra Copper without fail. The last time the intake was off was in '00 and no leaks
Old Jun 5, 2011 | 09:47 AM
  #17
My 381 went together in 2001 with Ultra Copper - no problems.
You don't have to use studs as guides for the manifold, you can use wooden dowels.
Old Jun 5, 2011 | 10:37 AM
  #18
tnts94z's Avatar
I also used the wooden dowels for studs and it worked great. Used the Ultra Copper and have had no issues either.
Old Jun 5, 2011 | 09:56 PM
  #19
Hooliganzhotrod's Avatar
Heres a trick I learned from an old school GM Technician. Take a center punch and put dimples on both ends of the block where you apply your RTV. The dimples in the metal will give the RTV something to hold onto after the Intake has been set. Ive been using this trick on every motor Ive ever torn down and havent had a leak yet.
The best RTV I have found is MOPAR black RTV for Engine repair and MOPAR Grey RTV for transmission and aluminum parts. It's only a couple bucks more a tube but well worth it.
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
$hawn
Aug 21, 2002 03:42 PM
