removing front seats
Old May 16, 2004 | 11:29 PM
klpps's Avatar
the leather in the front is cracking and peeling so i decided to replace em w/ some racing seats. is there a site where it gives a step by step on removing the seats? Showing which bolts to unscrew etc? thanks
Old May 16, 2004 | 11:52 PM
All you need to do is bend down and look under the seat. There are four studs attached to the floor, two at the front and two at the back of the seat. They may still have the little rubber caps that came from the factory. Remove the rubber caps, remove the nut from each stud. If you have a power seat, disconnect the harness connector, and lift the seat off the studs. Not very difficult at all.
When the seat is out, take the time to look at the studs where they attach to the floor. I found a couple of them starting to crack at the welds.
Old May 17, 2004 | 12:20 AM
1982z28with18s's Avatar
Yep, its very easy. Just slide the seat back and get the front bolts, then slide it up and get the back bolts.
Old May 17, 2004 | 12:29 AM
cndctrdj's Avatar
dont forget to unscrew the seat belts
Old May 17, 2004 | 11:46 AM
klpps's Avatar
im looking into getting this one pair of R1 seats off craigslist and it says it comes "with the sliders". Are there different sliders for different cars or are they pretty much universal?
Old May 17, 2004 | 12:41 PM
MikesGreenZ28's Avatar
most likely different, but u may be able to use the stock ones, not sure though.
Old May 17, 2004 | 12:43 PM
klpps's Avatar
anyone know for sure?
Old May 17, 2004 | 12:44 PM
Red96Lt1's Avatar
Not sure about the sliders, but if you want to keep acess to your back seats, they make reclining racing seats.
Old May 17, 2004 | 02:01 PM
billy-94z28's Avatar
corbeau seats recommend you buy their mounting brackets - and they are not too cheap either.
www.corbeau.com
Old May 17, 2004 | 02:37 PM
www.corbeau.com
They are also excessively heavy, and not "double locking" as required by NHRA. I saved 23# by replacing my stock, non-powered cloth seat with a Corbeau Forza, and then gave back 10# for the extra weight of the slider.
cmyname1
Feb 19, 2015 08:38 PM
siguy
Nov 27, 2014 10:07 AM
CamaroGuy719
Sep 16, 2002 04:58 PM
Lions3
Aug 18, 2002 11:12 AM
yosshimura
Aug 14, 2002 07:29 PM
