removing chrome
Old Jan 20, 2005 | 04:41 PM
LT4orbust's Avatar
Talking removing chrome
will sand blasting take the chome off of headers so i can have them coated, thanks....yeah,no shift button on the keyboard
Old Jan 20, 2005 | 04:49 PM
StickMaster's Avatar
Re: removing chrome
You could always get your girlfirend........nm.....i would think that would work.
Old Jan 20, 2005 | 04:50 PM
RamAir95TA's Avatar
Re: removing chrome
There are two common ways to remove chrome. The first is hydrochloric acid (muriatic acid). The second is reverse current alkaline stripping--essentially, putting the part in an electrocleaning tank.
The first is fast and simple, but can attack the substrate. The second will not attack the substrate but is more complicated, and it generates hexavalent chromium.
Rumor has it that bleach and oven cleaner work also.
Old Jan 20, 2005 | 07:11 PM
ShawnMacAnanny's Avatar
Re: removing chrome
Hexavalent chromium causes cancer and birth defects. Sand blasting should take it off.
Old Jan 20, 2005 | 07:35 PM
LT4orbust's Avatar
Re: removing chrome
thanks , are the insides coated when they do the outside and should the inside be done
Old Jan 20, 2005 | 09:18 PM
Silver's Avatar
Re: removing chrome
Old Jan 20, 2005 | 09:25 PM
Z06Z28's Avatar
Re: removing chrome
hey meanie, no laffing, ha... headers shouldnt be coated inside unless someone did a triple gold bling bling dip for car show purposes. If you sand blast it, I would definately not touch the inside, only the outside. Might wanna wad the tube ends so you dont accidently hit the insides....
Originally Posted by Silver
Old Jan 20, 2005 | 09:27 PM
Z06Z28's Avatar
Re: removing chrome
you describing a darn Twinkie? I always wondered what that creamy filling was.....
Old Jan 20, 2005 | 09:33 PM
Re: removing chrome
No Mr. Slurpee, i am describing Erin Brockovich, starring Julia Roberts .
Old Jan 21, 2005 | 01:04 AM
Brent94Z's Avatar
Super Moderator
Re: removing chrome
Coaters will prep the headers for you. Are you wanting to do this yourself to try and save a few bucks? If not, you should be able to just send them to the coater as is and they'll prep em for ya
Old Jan 21, 2005 | 07:12 AM
LT4orbust's Avatar
Talking Re: removing chrome
i called one of the coating companys and they almost doubled the cost of coating if they had to strip them, i have a 34 cfm at 200psi compressor that'll make the job easy,btw sliver or was it silver... what would be the problem with coating the inside
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Jul 10, 2015 06:29 PM
CARiD
Jul 7, 2015 08:19 AM
shroyvin56
Apr 19, 2015 09:40 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
