Removing the cat
Old Aug 26, 2003 | 12:49 PM
siggesnake's Avatar
Removing the cat
Hello i wonder if it safe to remove the cat on a camaro 94 350lt1
whithout any problems whith thr ecu
Old Aug 26, 2003 | 12:54 PM
Chuckels's Avatar
It is safe but depending on what exhaust you have your computer might pick up knock. This can be fixed with an LT4 knock module. My only other advice is to watch your oil pressure switch which is right above the oil filter it hit mine with my y pipe when i took it down and it costs 40 bucks for a new one not to mention i though that i didnt have any oil pressure at the track.
Old Aug 26, 2003 | 01:46 PM
jasons93z's Avatar
your pcm wouldnt even know its gone since you have an ob1. I would do it if you dont live in an emissions state. I had good results with mine, but then again, my old one was clogged
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
