removing ac compressor
Old Apr 5, 2007 | 03:26 PM
red 95 z28 lt1's Avatar
how hard is it to remove the ac compressor (im getting rid of my a/c) it looks kind of hard to remove what has to be removed in order to get to it or get it out, ive done a search but its not for what im looking for
thanks
Old Apr 5, 2007 | 05:48 PM
96ZED28's Avatar
Hey Red,
I removed mine along time ago but if memory serves it wasn't that difficult at all, most from underneath the car is where you access the bolts. I think I loosened off the tranny coolant lines at the rad, removed the serpentine belt of course, I think there is 1 bolt that holds the a/c lines onto the compressor and 2 maybe 3 bolts holding the compressor to the block and then remove from under the car, nothing stands out about being that difficult. The a/c delete pulley was easy to install and I used the same belt as it was pretty much brand new. Good luck....
Colin
Old Apr 5, 2007 | 06:21 PM
krispy's Avatar
You do need the AC delete pulley/bracket.
The uninstall is straight forward, 3 bolts holding the compressor to the accessory bracket, 1 bolt in the rear holding both the inlet and outlet pipes to the compressor, and I think 1/2 more bolts holding tranny lines in place.
My suggestion is to disconnect the coolant fans and remove the whole assembly. I could not get the A/C compressor out without doing so, screwed with it for about 4 hours with no luck. After I took the fan assembly out (its held in by plastic tabs+gravity, incredibly easy to remove, just have to work the plastic tabs past the radiator lines) it took about 15s to remove.
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
AtlasXVIII
Aug 24, 2015 11:41 PM
malikot02SS
Aug 15, 2015 01:11 PM
colts0455
Jul 7, 2015 07:19 PM
