Remove heater core? how? where?
Old Apr 26, 2004 | 02:20 PM
sabre81's Avatar
i want to remove my heater core, is this a difficult job? Should i do it ? my car never sees cold weather, and i never use defrosters or anything? i figured id save the weight and eliminate a potential future problem.
Old Apr 26, 2004 | 02:30 PM
aram's Avatar
You need to remove the entire dash assembly. Then there are a bunch of bolts holding the entire heater box in place. There is one directly behind the engine thats hard to see. It's kind of a pain to remove it without breaking the whole thing. Figure at least a couple solid hours to do it and possibly having someone to help you when pulling the dash out. You also need to buy or make a plate to cover the giant hole that will be left in your firewall too. If you remove all that garbage behind the dash and all the heater hoses and stuff there is a lot of weight to be saved and it cleans up the engine bay a lot.
I got caught in a freak rainstorm the first time I drove my car after I removed all the heater and AC parts and you realize what the heater is for then. It was interesting sticking my head out the window while it was pouring because I couldn't see past the fogged up window (that and my wipers decided to not work).
Old Apr 26, 2004 | 03:20 PM
You don't have to take the whole dash out just to remove the heater core. There is a cover on the inside to remove and the hoses and a retainer between the pipes on the outside. I have seen some posts where people said it was much easier than they thought.
Old Apr 26, 2004 | 03:55 PM
aram's Avatar
I took everything out behind the dash that I could find when I pulled mine out. That included all the plastic hvac tubing, heater boxes, sound deadening, etc..
When I pulled the thing I honestly didn't see a way to pull just the core out. My bad.
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Boss002
Jan 20, 2016 12:17 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
ducttape1975
Jul 10, 2015 06:29 PM
