Where does this go To?
Old Apr 26, 2004 | 03:05 PM
HoneyCombs's Avatar
When I got into my car accident this vaccum tank fell out of my car. http://shbox.com/1/vacuum_tank.jpg My question is what is the vaccum feed line from the check vavle exactly? another pic http://shbox.com/1/vac_tank.jpg
Matt
Old Apr 26, 2004 | 03:17 PM
OBE1 95Z28's Avatar
The vacuum tank located behind/below the passenger side headlight. If you remove the lower access panel and look straight up, you'll see where it should mount. The check valve line should be hanging in that area to connect to the tank.
Old Apr 26, 2004 | 03:28 PM
Not sure what you mean by "My question is what is the vaccum feed line from the check vavle exactly?"
It is the hose that goes from the check valve to the vacuum tank. It is threaded in with the electrical wiring that runs along the RH shock tower to below the battery.
Old Apr 26, 2004 | 04:05 PM
HoneyCombs's Avatar
Thanks for the help guys
