Removal of AIR pump hard lines?
I just finishing up my Jet Hot Lt install and was wondering if there was a way to take out the AIR hard line without having to cut it into pieces. How hard is it to do? I wouldn't care to cut it, but I didn't want to destroy it if I sold I my car in the future and needed to smog it(CA law, seller has to smog car). Where I live now I don't have to smog it just only when I sell it. I can see where it is bolted in two areas, but I thought it would be near impossible to try and manuever it out of there. Someone let me know if they have done this and what was involved.
Re: Removal of AIR pump hard lines?
Originally posted by drewstealth
I'm not sure but i would like to know also. Mine is still on there. Just a quick question why don't you have to smog your car in San Jose? Or do you live somewhere else now?
I hacked the SHlT outta mine and did it with a smile on my face. It was about time that piece of crap was out of my car. I dont see how it can be done. I couldnt get mine out and the headers were off too.
I made a single, neat cut, using a cutoff wheel on a Dremel, right at the bottom under the timing cover. That way, all you need to do is reconnect it with a hose and some clamps if you have to put it back on.
I took mine off in one piece. I was also removing the a/c compressor at the time however. Its hard to say if it is even possible to take the hard line off in one piece without a significant amount of room. At the very least, it would be extremely difficult.
maybe its slightly different on 93's. I just went in the garage to make sure my memory is correct b/c it was about 2 years ago and it's all in one piece. Headers were intalled. It was one of the last things I did.
I had to cut mine but now I have to figure out how to get one back on. I was thinking if I removed the accessory bracket it would be easy to slide in after that was out of the way. If you call removing all the accesories easy
I will let you guys know I am going to tackle this in the next couple of days.
-Matt
I will let you guys know I am going to tackle this in the next couple of days.-Matt
CamaroZBoy
Sep 9, 2002 10:33 AM
