Reinstalling Opti...how to line up the holes? Please help
Old Jan 27, 2004 | 02:41 PM
95BlackTA's Avatar
Well im putting the opti back in there, and There is that square side, and then two circlular ones. Do those have to go a certain way? In the hole I see 3 bolts, and then 1 lil dowel thing sticking out. Does that have to go inside of the square hole on the opti or what. How do I know?
Please help me out, gotta get this right before i put the car back together. Thanks guys.
Old Jan 27, 2004 | 02:47 PM
Opti
Old Jan 27, 2004 | 04:57 PM
Tires_Smokin's Avatar
This is what I did..
(nice pic by the way shoebox)
Since you now know where to put the pin into.....Here's a tip on trying to fit it on.
You might need someone assist you first off. I had a buddy shine a light down into the timing cover where the opti drive goes. The hole on the opti pin will line up with the cam dowel pin when you insert the opti. When you think you lined up the hole on the opti pin to the pin on the cam...push the opti in and you might need to have your buddy wiggle the crank pulley so it pops into place or whatever up the opti drive. Once it slides in, push the opti in gently and there you go....make sure it's lined up because it may appear in, but the cam bolts may not be lined up into the opti drive spinny thing, ha ha that was technical. Anyhow...just use patience....that's what I did...hope this helps.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
Spcquinn
Apr 18, 2015 09:40 AM
beltrunner
Apr 15, 2015 01:10 AM
carl.froehlich
Mar 13, 2015 12:38 AM
