Regular oil pressure readings?! No probs, just curious-
Old Jul 16, 2005 | 03:50 AM
AlwaysCode390's Avatar
Question Regular oil pressure readings?! No probs, just curious-
Hey guys, I did a search and after reading through 20 pages of oil pressure PROBLEMS, I wasnt finding just the regular readings people have when their system is HEALTHY. My car is about 60 at startup and on the highway, and from 30-40 when I am driving stop and go. It doesnt bounce but fluctuates with speed. My motor was recently rebuilt, do you think I have a high flow pump in there or are these stock specs that I am getting. Thanks--
Old Jul 16, 2005 | 04:27 AM
Silvershark's Avatar
Re: Regular oil pressure readings?! No probs, just curious-
I just rebuilt my motor with a new stock pump, but with the white pressure spring and my oil pressure on idle is at 60psi and at cruising it is around 30-40psi. So I would say your oil pressure is fine.
Old Jul 16, 2005 | 01:09 PM
Thank you
Old Jul 16, 2005 | 02:59 PM
nin97's Avatar
my cruising oil pressure is about 40psi
but my idle is lower...like 22psi...
that doesn't seem right (my oil pressure that is) any help?
Old Jul 16, 2005 | 03:00 PM
Paul87's Avatar
Heck, my oil pressure at a warm idle is around 10-15, i don't think that's good
Old Jul 16, 2005 | 03:10 PM
nin97's Avatar
yikes
i've been a bit worried the last few days...cant stop thinking about the oil pressure...in fact i've even thought about selling it and maybe picking up an LS1 SS (id have to save some money for a while though)
how bad is it? 20-22psi at warm idle...cold idle is a lot higher (40+)
Old Jul 17, 2005 | 12:05 AM
Lt1t56's Avatar
If Iam not mistaken, GM specs for oil pressure at idle with engine at operating temperature is 18-20 psi. My Z that I recently sold was that way and the T/A that I still own is that way, no problems to mention.
Old Jul 17, 2005 | 12:13 AM
94Z28WP's Avatar
Mine has read just below the first mark at warm idle since I bought it... No problems.. The rule of thumb used to be, at least 10psi for every 1000 rpm... I'm sure that still applies.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
