Did I screw up?
Old Jul 16, 2005 | 05:10 AM
Demus's Avatar
Did I screw up?
I was swapping cams today and to get the crank hub off I used a slide hammer /w crows foot end on it. It didn't work very well so I ended up going out to buy the right puller. Anyway, would using the slide hammer have damaged any bearings or anything?
Old Jul 16, 2005 | 06:30 AM
ibanez6rg's Avatar
Re: Did I screw up?
It's possible.
Old Jul 16, 2005 | 09:08 AM
ZMAN Z28's Avatar
Re: Did I screw up?
Take a 3/8" bolt. Cut or grind it 3 and 1/4 " from the bottom of the head. Put it in the middle of the crank hub. Put the puller on and remove the hub. It will come out pretty easy. The hub has a ridge inside itself, so if you use the crank hub bolt or a puller, it will just try to back out on itself, possibly causing damage.
ZMAN
Old Jul 16, 2005 | 09:24 AM
Re: Did I screw up?
ZMAN
I don't think that was his question.
I'm not sure how you had enough room to get a slide hammer in there. Is the engine in the car? You probably did not generate enough force with the slide hammer to harm anything.
Old Jul 16, 2005 | 11:29 AM
ZMAN Z28's Avatar
Re: Did I screw up?
Sorry
Old Jul 16, 2005 | 01:53 PM
Demus's Avatar
Re: Did I screw up?
Yes, the engine was out of the car. I'm not a very strong guy, but I did give it a lot of force. The hub didn't budge one bit with the slide hammer. Oh well, I guess we'll just have to wait and see.
Old Jul 16, 2005 | 05:33 PM
ZMAN Z28's Avatar
Re: Did I screw up?
If you have access to a 3 arm puller, try the method I mentioned earlier. Acually credit is due to LT1TKO50 for teaching me that one.
ZMAN
Old Jul 17, 2005 | 01:14 AM
1racerdude's Avatar
Re: Did I screw up?
Chances are ya didn't hurt a thing with a small slide hammer.
One with a 10lb slide might damage the thrust main brg but I don't think ya had one that big.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
Z28Freak86
Apr 28, 2015 10:35 PM
squarehead
Nov 21, 2014 08:02 PM
