Redline?
Old May 30, 2004 | 02:25 AM
Z28WannaB's Avatar
Redline?
I have a 95' Trans AM A4, and the transmission is broken. 3rd and 4th gear are completely gone.
Anyways I was racing some 99+ Gt Stang, which I kicked his *** all the way up until about 80MPH when I noticed I was at approximately 6,000RPM in second gear.
Do these cars not have limiters? I had the car put in second, because if you put it in drive it trys to switch to 3rd and you just free rev.
When does the limiter kick in? Could my gauges be off?
- Z28WannaB
Old May 30, 2004 | 02:43 PM
Josh'95Z28conv's Avatar
Re: Redline?
- Z28WannaB
5800 RPM, yes
Old Jun 15, 2004 | 08:22 PM
elament's Avatar
The rev limiter should have kicked in at about 6000 rpm. I don't think your gauges are off, the fact that your missing 3-4 isn't good, if you are going to rebuild that tranny, you don't want to get it too hot, and check your oil from time to time, I had a sweet 91 chevy pickup I fried third and forth and drove it all the time tacking it up in second. The engin ran hot and burnd my oil slowly, I wound up throwing two piston caps through my oil pan.
Old Jun 15, 2004 | 08:44 PM
ScrmngChckn95's Avatar
Isn't the fuel cutoff at about 6100? It is on my m6.
Old Jun 15, 2004 | 09:08 PM
JoeliusZ28's Avatar
factory rev limiter is 6200 rpm... and its a spark cutoff setup rather than a fuel cutoff I believe.
Old Jun 15, 2004 | 10:21 PM
I could have swore it was 5800
Old Jun 15, 2004 | 10:37 PM
JoeliusZ28's Avatar
well thats the redline
Flint78
Jun 21, 2015 01:28 PM
warmeck
May 7, 2015 02:10 PM
Nickster 7
May 1, 2015 09:04 PM
bossco
Nov 29, 2014 10:18 AM
The Captain
V6 Tech
Mar 28, 2003 10:32 AM
