Recurring codes
Old Jul 29, 2007 | 08:59 PM
BLDun's Avatar
Recurring codes
I keep getting a 91 - skip shift lamp circuit; and an 84 - Transmission 3-2 control solenoid circuit. I clear them out but they just return. Questions: how do I solve them permanently; will either create a problem of any sort and exactly what do they mean??
Old Jul 30, 2007 | 01:10 AM
theratdude64's Avatar
3-2 is kind of a weird code with a manual. I could be wrong though? Hrm. What are you using to read codes BTW? 93+ Doesnt blink check engine lights, so that sucks.
Old Jul 30, 2007 | 05:31 AM
BLDun's Avatar
I have a ScanMaster directly hooked to the car and mounted in the guage pod. The code readings are from it.
Old Jul 30, 2007 | 01:11 PM
You have to use the correct code list.
http://shbox.com/1/Dtcs.htm
There is a DTC 84 for the A4 (3-2 Control Solenoid Circuit) and for the M6 (Skip shift solenoid circuit). Since you have an M6, it indicates your skip shift solenoid is unplugged or burned out. DTC 91 would indicate the skip shift lamp is burned out, or the wire has been cut or disconnected at the PCM connector. To clear DTC 84, plug a 2.2Kohm resistor into the harness connector, or but a "skip shift eliminator". To clear DTC 91, either replace the bulb or reconnect the wire.
Old Jul 30, 2007 | 02:04 PM
BLDun's Avatar
Thanks. I will take care of it.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
