recommended rear fluid?
Old Aug 5, 2003 | 10:13 AM
JuiSSed's Avatar
i'd like to change my fluid, which ones are you guys using?
thanks
vinnie
Old Aug 5, 2003 | 10:36 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Redline all the way. When it comes to fluid, i always use redline.
Chris
Old Aug 5, 2003 | 03:04 PM
BigRich's Avatar
Redline 70W-90 or Heavy Shockproof
Sam Strano says Heavy Shockproof is good for take-off Torsen diff and autox
Old Aug 5, 2003 | 03:31 PM
predator's Avatar
80-90 gl-5 lubricant with40z of limited slip additive
Old Aug 5, 2003 | 04:11 PM
jkipp84's Avatar
I used Mobil 1 and the GM additive when I did mine last summer. All is well.
Old Aug 5, 2003 | 05:06 PM
BUBBA's Avatar
I believe most gear oil is pretty much the same. I use 75w90 Quaker State Synthetic with GM additive in my torson.
Probably would have gone with Mobil 1 if Jiffy Lube carried it.
It came from SLP with the QS 75w90 syn.
Old Aug 6, 2003 | 01:55 AM
JuiSSed's Avatar
i'm actually swapping gears.. i've heard not to break in gears with synthetics.. just regular oil.. then change to synthetics down the line.. is this true?
thanks
vinnie
Old Aug 6, 2003 | 12:34 PM
akrott1's Avatar
What year is your car and which rear end do you have.....
This is my understanding:
- For the earlier 4th gen's 93-97 you do not want to use synthetic, you will want to use and 80w90 with one bottle of GM additive. I put Mobil 1 synthetic with one bottle in last year and just changed back to the standard as I was having trouble with my posi engaging and was told it was because the clutches in the posi unit do not like synthetic. Changed it back and can't believe the improvement.
- For the new 4th gen's that have hte Zexel/Torsion, I think they like Synthetic a little better.
Later
Aaron
Old Aug 7, 2003 | 10:52 AM
JuiSSed's Avatar
i have a 96 SS with the Torsen.. i didnt add the additive because there are no clutches in my diff.. i used 80w90 regular oil.. i'll switch to synthetics in about 1000 miles.. should i have done different?
thanks
vinnie
CGM2010CAMARO
Apr 7, 2015 07:44 PM
warmeck
Mar 16, 2015 07:02 AM
WildRidez
Feb 23, 2015 07:24 PM
alex5366
Feb 17, 2015 10:43 PM
FredM
Dec 18, 2014 01:40 PM
