Rebuild $$$
Old Sep 8, 2003 | 12:30 PM
94camaroz28luc's Avatar
Rebuild $$$
How much should I expect to pay for an engine rebuild?
94 Z28
350 5.7
Automatic
Does anyone know a good shop between the Lexington,KY & Cincinnati, OH area??
Old Sep 8, 2003 | 01:10 PM
This should be posted in "LT1 Tech"..... moving it there.
Old Sep 8, 2003 | 02:16 PM
zx1216's Avatar
When i rebuilt my 350 sb for my 79' z last year it cost me around $1300 re-useing everything except the pistons. That was with me removing/installing the motor.
Old Sep 8, 2003 | 04:26 PM
Perry93TransAm's Avatar
I just rebuilt an 88 350 TPI motor for a freind and I reused all the rotating assembly. I reground the crank,resized the rods and put in ARP bolts, cleaned up the pistons and reused them, the cylenders were absolutely perfect for 178,000 miles so I just unglazed the cylenders and called it good, We got a set of heads rebuilt off E-bay for 300$. The only new stuff I bought besides the obvious (rings , main and rod bearings, gaskets, freeze plugs, and cam bearings) was an oilpump and a cam (crane). I used oven cleaner on the block instead of having it vatted. I also did all the assembly and r +r myself.
Old Sep 8, 2003 | 04:54 PM
magius231's Avatar
wow 7 years ago I built my 350 for $500 worth of machine work and $300 worth of rebuild parts - including new pistons...it can be done for cheap
oh, no head work there...
Old Sep 8, 2003 | 06:06 PM
wayne97's Avatar
ttt
Old Sep 8, 2003 | 06:25 PM
BOWTYDE's Avatar
To have it all done professionaly to stock specs really depens on what the condidtion of the engien is in.
Assuming you just spun a bearing and no major other damage (side walls, rods, and what not) your looking at abour $2,500-$3,000. There is alot of labor in dropping the motor and the rebuild itself, the kit is realtivly inexpansive.
IMO: You might want to look at some performance parts to build it out with while it is open to save you some money down the road. I think it would be safe to say most guys on this board don't rebuild to bone stock.
Old Sep 8, 2003 | 06:28 PM
AxeGrinder30thZ's Avatar
All I know is, when it's time for me to rebuild, the car will be turned into a 383 or 396.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
