Reasons not to get 17x11's?
Remember what 97WS6SCharged said about offset front/rear sizes. You won't be able to rotate them, and will spend money on tires more often than if you went with the same size all the way around. If you can afford that, then more power to ya.
Originally posted by Heatmaker
These cars Deserve a 17X11 Rear I'm telling you.
No regrets...tires are only like 40bucks more.
I've wondered the same thing about 17x11 vs 17x9.5's. Since there is no rotation of the tires, wouldnt the fronts last longer than the rears, even without doing burnouts, because of the RWD? Which is TRULY better for rain traction? Which would be better for snow?
yea guys i was wanting to know more on this topic also. i want 315-35/17s on my rears alos. i want to pick me up a set of the afs 17" zr-1 chrome wheels fronts 17x9.5 and rears 17x11s. i dont wnat to have to roll my fenders or do anythign special just want to bolt them on and be done with ti. i hope the tractino is better in the rain like some of you said it is and some said its not. i have just stockes 245/50-16s on my car with soem bf goodrich g force t/a kdws tires. they are aweseom in the ddry and wet and they get pretty good treadlife. there like a bargain tiere. but thats the wheel tire set up i want. i love the look of 315s. arent the viper's raears 335s? man they are some huge tires. i want the 17x11s bad!!!!!!!!! sweet huge wide tiers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! what do you guys think yea or nea?
If you honestly want the car to perform better than a 9.5 inch tire is more than wide enough.. what's key is the tire compound.. drag radials will do wonders.
If you really want an optimum setup I'd stick with 16 inch even.. or maybe downsize to 15. If you want the car to handle though and hook I think 16's are a perfect compromise.
You can rotate the tires, the rims are better protected from road hazards, ride is smoother, straightline traction is as good or better, rotational weight is far less, and tires are much cheaper. What more do you want?
Of course, most people here will probably shoot me for saying 16x8 or 16x9 is ideal.. for no other reason than for looks.. but I say this is a muscle car that's mean't to have some rubber to burn.. no rubber bands on my car
As others have said, it all depends on what you want and what you expect from your car. No doubt 315's look cool but I certainly wouldn't say they're in any way practical or worthwhile for anything more than just looks.
My .02
My .02
I put my 315's on my9.5 inch rim w/ no problem, alot of brands are almost to narrow for an 11 inch rim and look funny. nitto 315 aren't much wider than bfg d.r. 275. I run sumitomo and got -em pretty cheap at tire rack..
I ran 315 nittos for almost a year. They were direct bolt on with a pair of weld wheels, and actually weighed less stock.
I did lose a mpg or two with them, and it was a daily driver (80 miles/day). The only reason I sold them was because I went with 15" telstars with skinnies up front. I can tell you this though, the 315's on 17" wheels hooked so much better than these 275's on 15" wheels (both sets of tires being nitto drag radials). I put ~30k miles on my car each year and can get 15k out of a set of nittos. So thats two sets I have to buy each year compared to one set of non drag radial tires. I'd rather spend the extra $375/yr to have drag radials. Also have to remember that most of the 17x11 wheels are very heavy. IMO though, get them.
I have found that not every tire shop can mount or dis-mount tires less than 40 series do to machine limitations. My concern was being able to get a flat repair on a trip. So I just stuck with 9.5's. I love the S@#$ out of my BFG G-Force TA's
Oh and chrome rims clean up real easy too. I never had them until recently.
That was the reason you stayed with 9.5s huh? Jeez.
to be mathmatical about driving in rain or snow.
The wider the tire, the weight on each wheel is the same but its distributed much better, giving u less weight per square inch of contact w/ the ground. that less weight will in turn be unable to push as mush water out from underneath the tire.
using tread designs it is possible to make some tires more accomidating to rain and snow, but it probably means there is less tread in contact w/ the ground making for a higher wear rate.
but if ur not gonna be driving in the rain u dont need to worry about this stuff
