Rear o2 sensor question
Old Dec 20, 2004 | 10:30 AM
Beyonce Knowles's Avatar
I have a quick question about the rear o2 sensors. I know their main purpose is to tell the PCM if the converters are working right, but is that it? If they tell it that they are not working, will the car run any different or will it just throw a code and the SES light? The reason I ask is because I am in the middle of installing some long tubes and I don't want to shell out $50 for sims when I'll just have tuned out in a few months (after I get a cam). I will be driving it b/t now and then, so does anybody see a problem with not using any rear sensors/sims at all?
Old Dec 20, 2004 | 10:37 AM
Dave19yz28's Avatar
Re: Rear o2 sensor question
you're ses light will go on...but other than that should be just fine.
I have a set of sims for sale if you want...$30 shipped.
Old Dec 20, 2004 | 12:44 PM
stereomandan's Avatar
Yea, the SES light will stay on, but other than that, absolutely nothing will be affected, except the ozone.
I'll take the sims if he doesn't, if you take paypal. PM me if he doesn't want them. Mine are already programmed out, but I would like to plug the rear O2 connectors with something, instead of having them open.
Old Dec 20, 2004 | 08:41 PM
Great. I don't want the sims. I'll be getting a tune in a few months, I'll live with the light until then. Thanks.
Old Dec 20, 2004 | 08:56 PM
jdizzell's Avatar
The rear O2's will change injector pulse width to find 14.7 afr non-wot, so if you are running no cat your injector pusle width will be shorthen and your long term will change also. If you are just running long tubes, I think you will be ok.
Old Dec 20, 2004 | 09:21 PM
Really? This sounds different than the other two. Does anybody else agree with this guy?
Old Dec 20, 2004 | 09:28 PM
You're talking about the front O2 sensors. The rear O2's don't adjust a/f ratio.
Dan
Old Dec 20, 2004 | 09:34 PM
jdizzell's Avatar
Rear o2 also do the same as far as changing injector pulse width. I will double check tomorrow with my gm master tech.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Patricklt1
Apr 24, 2015 06:29 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Jul 4, 2005 05:00 PM
